Re: negleted M
Posted by ScottyHOMEy on September 02, 2008 at 02:42:17 from (70.105.240.66):
In Reply to: negleted M posted by T BENSON on September 01, 2008 at 21:27:03:
First two things I'd check is the torque on the head and the underside of the water jacket.
If you're lucky it will be the head gasket. They do need to be retorqued after warming the engine after you've installed a new one.
You might also drop your oil pan and look up at the underside of the waterjacket to see if there's any obvious signs of leaking that would indicte a crack there.
Good luck!
