Re: Farmall M (LOCKED REAR END)
Posted by Gene Bender on September 02, 2008 at 04:21:43 from (67.55.226.165):
In Reply to: Farmall M (LOCKED REAR END) posted by Jeff Hostler on September 01, 2008 at 21:04:19:
Does the shifr lever work in all the gears? You mite just have the tranny locked in two gears at the same time.Remove the shift lever by driving out the pin then looking thru the hole check and make sure the rails are all lined up. It mite be easier to align the rails with one wheel jacked up and have the clutch pedal forward to remove any tension in the tranny.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
