Re: Did I run out of fuel?
Posted by farmallkid1958 on September 02, 2008 at 04:30:49 from (216.21.189.125):
In Reply to: Did I run out of fuel? posted by Michael Price on September 01, 2008 at 20:15:00:
We had a 584 and we always had a problem of getting spider/bugs in our tank and plugging the line right where it comes out of the tank. we would take an air hose and blow back thru the line that we took off at the fuel filter. It would work for a while until the bugs would settle back to the line and we would have to do it again in a couple months. We finally figured out that the spiders would crawl in the fuel nozzle from our over head tank and build a nest and then you would pump them right in not knowing. If you don't use the fuel tank/nozzle very often, they will help themselves.
