Re: Farmall M (LOCKED REAR END)
Posted by mkirsch on September 02, 2008 at 06:01:18 from (64.80.110.50):
In Reply to: Farmall M (LOCKED REAR END) posted by Jeff Hostler on September 01, 2008 at 21:04:19:
If it happened while you were stopping to shift, then it is stuck in two gears at once. The nub on the end of your shifter lever is worn down and will slip out of place unless you are very careful about how you shift.
Pulling it is a good way to really break it. It's not broke now, but continue to try to force it, and you will break something.
