Posted by CNKS on September 02, 2008 at 09:32:26 from (216.144.104.128):
In Reply to: Re: new rear wheels posted by jay snyder on September 01, 2008 at 19:33:29:
I have not seen what you have, but the original bolts had nuts, and were just pushed through the holes. Also, double bevel means two "humps", either of which can be used to attach to the hub, allows different rim spacings on the wheel. Sounds to me like you have a "drop center" rim with a little wider drop. If so, be sure you get them tight and check after running a while that nothing has moved. Also, be sure that the rim has the horizontal bars welded on that keep the rim from slipping on the hub.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
