Re: H-Trans
Posted by Owen Aaland on September 02, 2008 at 11:35:50 from (65.161.86.52):
In Reply to: H-Trans posted by Eppe Dad on September 01, 2008 at 18:05:19:
On the Hs I have worked on because they would not stay in 5th, all were cured by replacing the front mainshaft bearing. The bearing is mounted on the front of the mainshaft and rides in the back of the input shaft. When the bearing gets worn it allows the front of the mainshaft to wobble and it will walk the 5th gear out of engagement.
The bearing can be changed from the front after removing the hydraulic pump and transmission input shaft assembly.
