Posted by JimB2 on September 02, 2008 at 17:32:59 from (99.241.179.24):
In Reply to: IH B414 LOCKED UP posted by DARYLg on September 02, 2008 at 03:56:50:
Hi Daryl, do I read you correctly that you jacked up the tractor and went thru 1st to 4th and rev, gears and only the one wheel would turn? Did you have both wheels jacked at the same time? If both wheels jacked, did you try applying brake on wheel that turns? I would still check out the stuck brake theory on the side that doesn't turn as the brake disks are on the end of the bull pinion shaft from the differential. It is easier to remove the brake drum than the whole hydraulic housing under the seat to access the differential. The brake drum can be removed by removing the adjusting screw and then removing the 3 or 4 bolts that hold the drum to the diff housing. Look at caseih.com parts B414 and you will see the parts inside the diff and also check out the following posting on the same page as this one for: Farmall M (LOCKED REAR END) as the same applies for B414 as it has Bull gear on end of each axle.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
