Dust shields
Posted by GordoSD on September 02, 2008 at 17:41:53 from (66.115.200.140):
Does anyone have a good original dust shield for a SuperM or SMTA? I found one for an H, and took it to a fabricator . He duplicated it PERFECTLY! So if anyone needs one for the H series let me know.
Meanwhile I would like to "borrow" one from a SM and get some of those made. But I'm wondering if they made them for the SM's? My SMTA frame rails have the threaded 5/16 holes tapped in the frame rails where I believe they would go. Matches the holes tapped into the H rails. But I've never seen a dust shield that larger size. It's an almost flat panel about a foot long that goes under the space between the radiator and the engine. Alittle bend in it to allow water runoff.
