Re: advice for splitting super a
Posted by Gene Bender on September 02, 2008 at 19:49:31 from (67.55.226.165):
In Reply to: advice for splitting super a posted by Mark W. on September 02, 2008 at 10:13:29:
Better get some info on how to split the tractor in the I@T manual. Read it good as one end of the tractor will have to be able to move endways to remove the clutch parts. You should remove the flywheel and have the disc surface renewed. They will surface grind to renew the surface. Your kit will include a new pilot bearing also. You need to also get the adjustment rod cleaned so you can set the pedal play to insure that the throw-out bearing can do its job.
