Posted by Janicholson on September 02, 2008 at 20:01:57 from (66.173.50.164):
In Reply to: negleted M posted by T BENSON on September 01, 2008 at 21:27:03:
The plate you discuss below does cover the side of the block. Under it is coolant. Removing it will display about 50% of the sides of the cylinders (one side of each) The engine is a dry sleeve type. It has cast in place cylinder bores that are lined with a thin sleeve. This makes simple rebuilding possible. The sleeves and cylinder walls can easily crack with the water you indicated was in it, causing your issue. I would pull the pan, and look at the bottom end for coolant coming out of a cylinder between the piston and sleeve. If it is, it may need to have major machine work done. Putting a new repair sleeve into the block after machining out much of the old cast in place cylinder is first. Then that sleeve is machined out, counter bored and honed for a new thin sleeve. Best of luck, I hope it is simple like a soft plug in the block leaking. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
