Re: h brakes adjustment
Posted by dan g on September 03, 2008 at 03:28:22 from (208.103.139.96):
In Reply to: Re: h brakes adjustment posted by Andy Motteberg on September 02, 2008 at 16:49:55:
I think they changed the orientation of the wedge cam thing like in the "S" cam type heavy duty brakes from left to right. A drum brake should pull down on the brake lining against the drum when the pedal is pressed correct? Mine are doing the opposite to a degree then the right side bends over itself colapsing the band.
