Re: Starter switch/starter
Posted by Brownie 450 on September 03, 2008 at 03:34:04 from (216.51.158.151):
In Reply to: Starter switch/starter posted by edw on September 02, 2008 at 19:38:16:
Do as Jim says. When the starter switch is off, try touching the heavy battery cable to the starter contact to see if the starter turns.
