Re: D-358 Problems
Posted by MN Scott on September 03, 2008 at 06:39:30 from (206.9.216.81):
In Reply to: D-358 Problems posted by ihdoug on September 02, 2008 at 20:42:17:
Does the 886 use a cable or electronic solonoid to kill the motor? If its electric maybe thats the problem, short, burned out ect. Could be somthing in the pump maybe pump shaft. Remove the timeing window on the side of the pump and make sure its turning and also check the pump timeing. Could also be a stripped cam or idler gear. The cam still turns but is out of time and the engine will not fire. Also could be a stripped injection pump drive gear, the pump will turn but be out of time. Good luck and let us know what you find.
