Re: H farmall manifold
Posted by old on September 03, 2008 at 07:26:04 from (4.245.1.207):
In Reply to: H farmall manifold posted by jhb on September 03, 2008 at 04:14:47:
As the others have said. When its warm and the problem starts pull a plug wire and look at the spark. If its a yellow sort of spark then you have a spark problem. If its a nice blue white then you missed something in the carb most likely. But a carb problem is not likely unless it happens all the time
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
