Re: 6 or 12 Volt Starter?
Posted by Red Dave on September 03, 2008 at 10:55:16 from (66.216.141.163):
In Reply to: 6 or 12 Volt Starter? posted by Scott Walker on September 03, 2008 at 10:49:10:
"My H has a magneto ignition so I am assuming there is no connection to the other electrics on the machine." That is correct, the magneto is completely independant of any other tractor electrical systems.
A 6 volt starter will work fine on either 6 or 12 volts. Unless it has been replaced with a 12 volt starter at some point, it will be a 6 volt starter on an H.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
