Re: D-358 Problems
Posted by JimB2 on September 03, 2008 at 17:39:58 from (99.241.179.24):
In Reply to: D-358 Problems posted by ihdoug on September 02, 2008 at 20:42:17:
Hi, check the locking screw on the STOP/RUN control cable at the Bosch injection pump. Make sure when it is in the RUN position that the control lever is against the forward adjustment screw.
JimB
