Re: 560 diesel
Posted by Armand Tatro on September 03, 2008 at 19:12:02 from (98.227.135.78):
In Reply to: 560 diesel posted by oldfarmer on September 03, 2008 at 12:53:26:
There is a rubber hose on my 560D from the final filter to the fuel pump. About every 10 to 15 years this hose gets rotten and stops the fuel flow to the pump and needs to be replaced. If the tractor sits 4 or 5 hours you will appear to have plenty of fuel when you crack the fitting at the pump but if you check it after it stalls you will only have a few drips with the hose disconected. Install a new hose. Armand
