Posted by Janicholson on September 03, 2008 at 20:31:29 from (66.173.50.48):
In Reply to: farmall smtad ta posted by m.c. on September 03, 2008 at 16:53:41:
As CNKS indicates, the TA needs help. Fifth just makes it work. It will be stressed the same in all gears when pulling hard enough to pull the engine down to max power. A ramp and roller set and seals and a new TA clutch will probably make it new. Kevin Meier on this forum sells both rebuilt, and parts, at a reasonable cost. TAs are worth their weight in operational value. Do it. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
