Posted by glennster on September 04, 2008 at 07:07:24 from (99.131.129.77):
In Reply to: Super A - Not Starting posted by lance_MF_180 on September 04, 2008 at 06:45:56:
just a wild guess but i'm kinda thinking the distributor cap is wet. pull the cap off and wipe it off with a clean paper towel and see what it looks like. if there is any moisture there, pull the rotor and dust cover off, dry everything out with a hairdryer. i'd also pull the spark plugs and give em a cleaning, they are probably fuel fouled. also take the air cleaner tube off the carb before you try and start it. that way if the air cleaner is plugged, you can at least get the motor started and let it dry out. you can also spray some wd 40 in the distributor, it is good for moisture displacement.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
