Re: M@W live hyd distributor drive gear for Farmall MD
Posted by HemiMoparMan on September 04, 2008 at 09:45:32 from (97.97.6.26):
In Reply to: M@W live hyd distributor drive gear for Farmall MD posted by Andy Motteberg on September 04, 2008 at 04:55:59:
That one might be a little tougher to find.
You had better call Bruce at Bates Corp. 800-248-2955 he can probably help you.
Then you might try McGrew Equip. 717-428-0922
Good luck.
