Re: H BALLAST RESISTOR
Posted by Janicholson on September 04, 2008 at 10:51:20 from (199.17.6.128):
In Reply to: H BALLAST RESISTOR posted by RANDY DAUGHERTY on September 04, 2008 at 07:33:10:
I'll add that it will be too hot and might overheat if turned on while not running. The points (or electronic trigger in a electronic ignition) pass current substantially less than full time (about 50 to 75% of the time) Air is also moving around the resistor and coil when running. Do not leave it on not running. JimN
