Re: Farmall spark plug problem
Posted by Red Mist on September 04, 2008 at 18:58:26 from (72.171.0.138):
In Reply to: Farmall spark plug problem posted by John in Pennsylvania on September 04, 2008 at 18:48:38:
John in Pennsylvania said: (quoted from post at 18:48:38 09/04/08) I have a Farmall A that keeps fouling out plugs. I put in hot plugs but every now and again it starts missing. I pull the plugs and there is always one with a piece of carbon fouling it out. any suggestions
Well, you've probably got a lot of carbon in your engine. There are treatments which you spray into the intake to knock it out, or just use a controlled water injection to get rid of it.
Next, you are either burning oil and causing your plugs to foul, or you are running too rich and causing your plugs to foul. I cannot tell from the information you provided. So, either rebuild your engine, or lean out your carb. Maybe both. Otherwise, you are going to have a recurring problem of the same type as you describe. mike
