Re: Re: Re: A Wiring - Again
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Jim Becker on March 21, 2000 at 21:12:53 from (209.30.172.131):
In Reply to: Re: Re: A Wiring - Again posted by Dave on March 21, 2000 at 08:37:05:
It was probably put on either because someone thought it should be where (fixing something that wasn't broken)) or because it quit charging. This would give a fixed (medium level) charge rate if the field wire to the light switch is broken, if there is a problem in the light switch or any connection from the field wire through the light switch to ground is bad.
Post A Followup
: Re: Re: Re: Re: A Wiring - Again
