Posted by JimB2 on September 04, 2008 at 19:49:05 from (99.241.179.24):
In Reply to: 574 IH? posted by wants to know on September 04, 2008 at 19:37:30:
Does PTO turn, but requires hydraulic pressure to engage PTO clutch. Could be spline teeth are worn off pressure plate that drives the main PTO shaft that the hydraulic pumps runs off. Power steering will not work either, only by manual pump that is in steering mechanism. Only one hydraulic pump at 12 GPM and MCV valve splits 9 GPM to 3pt & remotes and 3 GPM to PS & PB. Check hydraulic fluid level with dip stick by your left heel when sitting on seat.
re I574D-RC, International 574 Diesel with D-239 German Diesel engine, RC, my guess is Row Crop with high front and rear wheels.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
