Posted by GordoSD on September 04, 2008 at 20:10:56 from (66.115.200.140):
In Reply to: Farmall spark plug problem posted by John in Pennsylvania on September 04, 2008 at 18:48:38:
A "piece of carbon" indicates a fuel mixture problem. Carbon is unburnt fuel. Oily, greasy wet plugs would be a valve/ring problem. Try leaning the fuel/air mixture. Also go up one more range hotter plu til you get burnt carbon.(orange/white)
Also try cleaning the plugs, then start the tractor and run at high idle. Shut off with ignition while at high idle. Check plugs.
Then clean the plugs and run at low idle. Shut off with ig switch. Will tell you where the rich mixture is.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
