Re: Maybe a legal question how do prove a tractor is yours?
Posted by Duanes on September 05, 2008 at 09:40:07 from (136.234.40.2):
In Reply to: Maybe a legal question how do prove a tractor is yours? posted by pb on September 05, 2008 at 06:20:19:
There is no paper work to prove it's yours or your uncles. There is also no paper work requesting that you do any work on the tractor or to store the tractor. Therefore,you more than likely could not charge your Uncle or the estate for your services . A judge would more than likely decide it belongs to your Grandpa's estate,if this was the case then more then likely the tractor would have to be sold and proceeds split off between your Dad and his siblings unless your Grandmother is living. The other option is you would have to buy out your Uncles share or he your Dads share. The value would have to be determined by a independent valuation. Was this not dealt with after your Grandfathers death in his estate? Is there anyone that witnessed your Grandfather giving this to you other than your Dad?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
