Re: 806 will not move
Posted by TractormanNC on September 05, 2008 at 16:32:46 from (209.42.180.157):
In Reply to: 806 will not move posted by joe71 on September 05, 2008 at 14:31:32:
Rust collector has you started on the right trail. If I may add to it.
If the PTO doesn't work, look for stripped splines in the clutch backing plate or the PTO drive shaft. Common problem.
If the PTO works, start looking at the MCV and its pump. You will DEFINITELY need a book for this.
