Re: Farmall A problem
Posted by old on September 05, 2008 at 19:16:38 from (4.244.6.223):
In Reply to: Re: Farmall A problem posted by john in pennsylvania on September 05, 2008 at 18:44:17:
Give his a try. Its a $2 gamble but might work. Mix 5 gal. of gas and 1 QT. of tranny fluid and run that and also put in 1/2 QT tranny fluid in the oil. Run it till you run out of gas. If it helps good if not then its time for some work. Oh by the way if you do the head do the rings etc or you will probably blow the bottom out. Things wear all at the same time and if the valves are bad so are the rings etc. BTDT and learned if you work on the top but not the bottom you will be soon
