Re: Farmall H irratic idle - Governor or ?
Posted by Janicholson on September 06, 2008 at 16:27:31 from (66.173.50.60):
In Reply to: Farmall H irratic idle - Governor or ? posted by PK Bodyman on September 05, 2008 at 21:01:28:
The "kill switch" is just a ground for the mag, so it is very unlikely that it messed up anything. If the stem bent on the switch, the switch could be intermittent, but not likely.
If a bit of crud got into the carb, it will act like this. There are two screws to adjust richness.
one for Idle, and one for high speed. Adjust these richer to see if changing them changes the pulsation speed or frequency. Be sure to keep good track of the number of partial turns 1/2 turn at a time, so you can go back to where it was. If it persists, I would super clean the carb again. JimN
