Re: 238 Utility Tractor.
Posted by JimB2 on September 06, 2008 at 16:58:52 from (99.241.179.24):
In Reply to: 238 Utility Tractor. posted by Dandy Dave on September 06, 2008 at 13:31:33:
Hi Dave, not familiar with IH 238 but am familiar with B414D. If it is like a B414D then it will have a British made BD154 ci engine with glow plug start. Now if it was assembled in USA it would have Delco Remy electrics instead of the dreaded Lucas electric that was on the British assembled ones. The BD154 engine was used in several industrial and ag models up to mid 1980s. B414,434,444,384,424,3414,3444,2444,7000 Forklift just some of the models.
If it is a BD154, BD154 will be stamped on the right side of the engine below the lift pump and hydraulic pump.
Part number for glow plug for BD154:
377206R92 GLOW PLUG
Hope this helps
JimB
