Thanks for the advice. I did remove and clean the carb again and used compressed air to blow everything out. Reassembled and still has an irratic idle. I removed the top Governor cover, and I can use a screwdriver to hold linkage steady. It will idle perfectly smooth, then eventually get in a fit where the governor starts it's up and down. I am 99% satisfied it is not electrical. My local Case IH service manager of 35+ years has told me this is the nicest original Farmall (of any model) he has ever seen. Just mentioning that so you know it's not a worn out piece of junk. My grandfather was relentless with his care and maintenance of this tractor. I am baffled as it has always run flawless and I see nothing obvious. Would replacing any of the Governor parts cure it?
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
