Re: cub engine
Posted by El Toro on September 06, 2008 at 18:00:57 from (205.188.116.73):
In Reply to: cub engine posted by DS Mi on September 06, 2008 at 17:24:43:
You need to get that crankshaft measured for wear.
I would pull the block and the crankshaft and take both to your local auto machine shop. They can measure the shaft and do a valve job. If the shaft needs to be ground undersize they can supply the correct bearings. Have them use a glaze breaker on the cylinders too. Hal
