?'s on 300
Posted by Mark from WI on September 06, 2008 at 18:20:30 from (72.160.255.99):
I'm going to put a new set of spark plugs in the 300. What is the best set of plugs to put in there? It has Autolite in there now. Is there a "hotter" plug to put in there to gain a few ponies? Also I am going to remove the belt pulley trans. I asked a few weeks ago about removing it. It looks like there is 4 bolts to remove is that right? However there are 2 bolts that look like they run up into the pulley casing from the trans on the tractor are those just alignment pegs? Hope it is easy to remove looks like there isn't much clearance! Any info is much appriecated. Thanks in advance!
