Re: B pilot busing removal
Posted by Jiles on September 06, 2008 at 20:58:03 from (209.183.34.49):
In Reply to: B pilot busing removal posted by jdjack on September 06, 2008 at 20:31:28:
If the bearing is a brass bushing and not a ball bearing, it can be removed by simply packing the hole with heavy grease and pump it out with hydraulic pressure created by driving a proper size metal or wooden shaft into the bushing hole.
This might work with a sealed ball bearing also, never tried it. Just be sure to dodge the escaping grease.
I have removed many bushings with this procedure.
