Re: When did Farmall first use elec starters?
Posted by tn terry t on September 07, 2008 at 06:48:50 from (205.188.116.144):
In Reply to: When did Farmall first use elec starters? posted by Cole on September 07, 2008 at 06:41:26:
i have a 1940 that came with the hole in the bellhousing with a cover over the hole but it did not have a ring gear on the flywheel also my neighbor has one that if i read the serial number is a 40 also and it does not have the hole on the bellhousing
