Farmall F-12 starting pain
Posted by 1031d on September 07, 2008 at 14:01:21 from (75.100.67.4):
I have a 1937 gas F-12 that has me stumped! It is rebuilt top to bottom. Before I painted it it would start sometimes with the hand crank. Now, it might start with the crank 1 time out of 10, but if I pull it it starts in 3 feet! What should I be looking at? Mag has new coil, points, and condenser, bit me once already, and a rebuilt fuel pump and carb. I did use the old throttle shaft in the carb because the new one didn"t fit quite right. The fuel pumps because as I crank it agitates the dirt in the fuel bowl. Most times I try to start it I can smell gas so I assume it"s getting plenty. All I know is it is going to a show on Friday and I can"t get it to run by itself!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
