With the live pump, you do not need the belly pump, except for a reservoir to store the fluid for the live pump. The Behlen power steering is a closed system. The hoses coming from the Behlen pump should go only to the steering torque motor, no where else. There should be one large hose (supply) from the bottom of the belly pump to the live pump, and one smaller hose from the live pump to a control valve of some sort. There should be one hose from that control valve that goes back to the fill pipe for the belly pump (return), and there should be two more hoses ( up pressure and down pressure)coming from that control valve and going to the loader cylinders. These hoses will probably have tee fittings, so that both cylinders can be supplied with hydraulic pressure. A picture would be worth a thousand words, but I don't have one.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
