Re: When did Farmall first use elec starters?
Posted by randy hall on September 07, 2008 at 14:45:30 from (209.143.0.64):
In Reply to: When did Farmall first use elec starters? posted by Cole on September 07, 2008 at 06:41:26:
i.m guessing that the first electric start from the factory for ih was the wk-40.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
