Re: uneven compression
Posted by Bob on September 07, 2008 at 21:55:02 from (69.178.228.68):
In Reply to: uneven compression posted by Jim Isler on September 07, 2008 at 20:42:25:
Valve TIMING will affect ALL cylinders equally.
Have you run this thing long enough under load to break it in?
What is the problem that lead to the compression check?
