Re: No S.N. tag
Posted by Hugh MacKay on September 08, 2008 at 02:35:55 from (216.208.58.183):
In Reply to: No S.N. tag posted by North G.L. on September 07, 2008 at 14:50:54:
North: Any IH number ending in R followed by number or numbers is a part number and in most cases it does not date the tractor, other than rare parts used one year only. I doubt if a Cub has any of those, it changed very little over the years.
On that engine serial number, not certain on the Cub, however all other IH had the machined flat surface just below number 1 spark plug on the right. Since the cub is a flathead that may not apply. It will be a machined surface with stamped digits rather than cast in place.
Bill was correct but a bit skimpy, U & T were both used in 1950 and V was not used. Other than those exceptions you just go forward or back from U & T in 1950
