Re: uneven compression
Posted by James Rumph on September 08, 2008 at 06:04:27 from (24.192.125.175):
In Reply to: uneven compression posted by Jim Isler on September 07, 2008 at 20:42:25:
Hook it to a plow and use it or if you know some one with a dyno hook it up and work it .
You didn't tell us how much run time is on the rebuild so we are guessing the rings havn't seated just yet.
I had a motor in my Super M that had lower compression when cold but great #s when warm.
I had a great head on it so it wasn't it. We reringed it because the ring end gaps were rather large and out of spec.
I had bought one of those kits and not checked the ring gap, lesson learned.
When you reringed it do you run a ball hone threw the cylinders to remove the glaze or just put new rings in the old cylinders ?
