If one side of the volt meter is grounded, and the other side is used to check the voltage at the switch, and when off it has volts on the input from the amp gauge, and when turned on that voltage goes away, the wire from the amp gauge, or the terminal/s are corroded. The volts should stay at 12v on both sides when on. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
