Re: Farmall Cub rear wheel bearings
Posted by Gene Bender on September 08, 2008 at 19:03:30 from (67.55.226.165):
In Reply to: Farmall Cub rear wheel bearings posted by tabor on September 08, 2008 at 15:44:06:
Take off the little cap on the inside of the final drive then remove the nut and the axle will slide out. You will have to remove the bottom pan to put back together so you can hold the bull gear to get the shaft back together.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
