Posted by Hugh MacKay on September 09, 2008 at 02:08:21 from (216.208.58.110):
In Reply to: Re: Leaking 140...??? posted by KRS_MED on September 08, 2008 at 18:30:23:
Keith: Check the hydraulic fluid level with both levers and front rockshafts in the rear position, (down if you prefer to call it that) and tractor not running. Fill to bottom of the filler plug. Before you put the plug back, start the tractor, and at low idle, operate the hydraulics through the full range several times. This will remove any air in the system, plus your certain it's not over full. If much air comes out during that you should shut tractor down and recheck fluid level.
The very best manual for you is the original IH operator's or owner's manual. Depending on tractor and year, it might be called either. Binder Books have the rights from CaseIH to reprint all these old manuals, and do a very good job of it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
