I think I would use flat nylon washers (from a good hardware shop) The use of Orings would reduce tightening pressure to the point of no gasket seal, or they would smash out. I think there are two contributing factors: The shifter needs a boot (CV joint boot slipped on, and clamped at the lever. Condensation and temp change causing breathing in the void above the fluid. When working them every few days till warm (or more) the heat drives out the moisture. When they become less often used, the become a distillery for water vapor. Ive thought that an oil heater would be good in the plug for use every month or so on a timer. JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
