Radiator Fan assembly for a Farmall 'C'
Posted by EDW on September 10, 2008 at 14:05:52 from (161.11.122.77):
Hello Folks; I have a question about mounting the radiator fan assembly and adjusting the belt tension. The Farmall 'C' I have seems to be missing something where the fan assembly is bolted onto the support. All I have is a slot for the threaded shaft to pass through and a nut to tighten with,. This just does not look like a good way to hold the fan assembly in place. Could someone let me know what is on their tractor. Thanks in advance!
