Re: H,M Brakes
Posted by RustyFarmall on September 11, 2008 at 14:05:35 from (209.152.78.71):
In Reply to: H,M Brakes posted by SRH on September 11, 2008 at 10:48:39:
There is an adjustment screw on the bottom of the brake cover. That screw may turned in too far, which will make the bottom of the band continually rub on the drum, or that screw may not be turned in far enough, which will allow the TOP of the band to drag on the drum. Somehow or other, through trial and error, you need to find a happy medium.
