Re: Long Term StoragePlanning
Posted by old on September 12, 2008 at 07:58:36 from (4.245.5.98):
In Reply to: Long Term StoragePlanning posted by InMN on September 12, 2008 at 07:07:23:
Oil in the cylinders, drain the gas tank and also put some oil in it to help keep it from rusting. A spray type oil in the tank works well because you can cover more of it. If you can also set it up on blocks to take the weight off the tires so if they do go flat they will be less likely to crack from sitting. If stored where mice could be a problem if you set it on blocks lay some sheet metal between the blocks and hanging over the edges of them so mice will not be able to climb the blocks and mess with wiring etc.
