Re: 12V conversion not starting/charging
Posted by Janicholson on September 12, 2008 at 09:44:11 from (199.17.6.128):
In Reply to: Re: 12V conversion not starting/charging posted by John T on September 11, 2008 at 14:57:14:
Idea is different.
Turn the switch to run crank (hand crank would also do) with pull or push rod mechanical starter switch. After it is running, momentarily turn it to start to excite the alt! Jim
