Posted by rust collector on September 12, 2008 at 13:10:36 from (130.18.53.203):
In Reply to: 1953 Super M Lift All posted by PitCrew on September 12, 2008 at 12:54:21:
If I remember correctly, there will be three ports that will have pressure when the "Lift-All" lever is pulled. Those went to the two front side cultivator cylinders and one to the back "tail" plows (1/2 inch pipe threads). It does not matter which port is connected if the other two are plugged. Unless you have a live pump mounted in front of the distributor with hoses going into the "Lift-All" unit, it will not be "Live". A belley pump will stop when the clutch is disengaged.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
